While both languages are applicable for web development, their popularity within the target industry still greatly depends on the efficiency and convenience each option features. While Python still holds the leading position as the world’s most used programming language, Go coding is only on its way to crawling up https://globalcloudteam.com/ the ladder. The 2022 study by Statista shows that every second developer is expertise in Python, while only 1 out of 10 specialists use Go in programming. In simple words, its design emphasizes safety, speed, concurrency, and parallelism and has zero-cost abstractions and memory safety without a garbage collector.
This means that you can work on multiple programs or applications at once and not worry about them interfering with each other. Your code is also able to handle multiple requests and be able to scale as needed. The Go programming language was designed by Google engineers who wanted a language that provided the efficiency of C++ but was easier to learn, write, read, and deploy. One of the main reasons Golang is becoming popular is because it is very efficient. The language is designed to be very lightweight, so it can be quickly compiled and run with minimal RAM and CPU usage.
Go for Web Development
Go is a modern programming language with capabilities to enable high-performance app development. With its growing web framework ecosystem, Go is a preferred choice for building complete web apps. This practical guide will enable you to take your Go skills to the next level building full stack apps. While the popularity of different programming languages varies from time to time, almost all website development platforms have their own favorite language.
It is less verbal and supports clean coding, which is important for machine learning projects and other data science problems. Go language will be the best in terms of high productivity, speed, and large scalability, it’s much simpler to debug and read for the programmers. It comes close to the speed of C/C++, is extremely easy to use, and enables reducing the manual memory management processes. Due to this, Golang will be the best fit for various system programming projects.
Go Web Server Example Code
This makes it ideal for web servers, which need to be able to handle a lot of requests quickly. Due to that fact, there are a lot of limitations and the phenomenon of dealing with low-level features in a high-level programming language. Its domain name is golang.org which is why some people call it Golang. Go, often referred to as Golang to help with internet searchability, is a statically typed, compiled programming language designed at Google by Robert Griesemer, Rob Pike, and Ken Thompson. The language is known for its simplicity and efficiency, both in terms of syntax and execution.
- Smith had been working in web development for a long time but began using Go soon after Google released it in 2007.
- With its growing web framework ecosystem, Go is a preferred choice for building complete web apps.
- It means developers must manually download packages from repositories and install them on your machine.
- Static typing provides better performance at runtime because it’s mostly used to build high-performance applications that are highly optimized at compile times.
- The only features added to this language are those that will make it much easier to use and enhance readability and maintainability.
This feature enables Go developers to use this language to create apps deployed on the cloud. Go is also an excellent system-level programming language and has capabilities offered by languages like C. The fasthttp framework provides a fast HTTP server and client API which was made as an alternative to net/http golang development company due to its limits on optimization opportunities. It is optimized for speed and can easily handle more than 100K qps and more than 1M concurrent keep-alive connections on modern hardware. It is also optimized for low memory usage and provides easy connection upgrade support via RequestCtx.Hijack.
How to authenticate React applications with Supabase Auth
Nanik Tolaramis based in Sydney and is a big fan of open source technologies and projects. He has developed software using many different programming languages – Assembler, C, C++, Java, Go and many others. He is passionate about building products and teams from the ground up, and loves to share his knowledge through meetup presentations and tutorials. He would like to thank his wife Jessie and sons – Rahul and Manav for being supportive in allowing him to spend weekends and countless hours sharing his passion for writing this book. Large companies such as Cloudflare, Netflix, and Dropbox choose Go for extremely different purposes and trust responsible tasks to it. Besides, it is one of the most frequently studied languages today—experienced Python and PHP developers master it and regularly use while working on their projects.
This course stands out since it’s more than just code snippets you’ll find on other sites. It’s a full blown, project-based course that guides you from start to finish. The background explanations for all the components and taking one approach over another are really helpful too. My progress was painfully slow, and every time I figure out one major problem I would be left with two new questions that weren’t addressed by the oversimplified tutorials. I can’t tell you the number of times I heard this when learning to build my first web app in Go. It isn’t that this advice is incorrect; it just isn’t that helpful by itself.
Featured users
With its goroutines, native compilation, and the URI-based package namespacing, Go code compiles to a single, small binary—with zero dependencies—making it very fast. These are the top 5 most used Golang web frameworks in 2020 compiled on the basis of popularity on GitHub. Every framework listed here has a different set of features to experiment and before implementing any of these frameworks, make sure that you clearly understand the requirements of the same.
Dawid is a full stack developer experienced in creating Ruby on Rails and React Native apps from naught to implementation. Technological superhero, delivering amazing solutions for our clients and helping them grow. If you want to make the development process easier or expand Go’s features, use frameworks such as Gin, Beego, Kit, Echo, Martini or fasthttp.
adjustReadingListIcon(data && data.hasProductInReadingList);
People want to build applications, online services and websites of all types. Before delving deeper into the comparison, let’s discuss about the two languages. They contain a sequence of instructions called statements which we want our computer to perform. In other programming languages functions are also called routines, sub-routines, procedures or methods. The Go compiler takes source code and translates it into the native language the computer speaks . Go programs are broken up into packages, with a package called main being the entry point for a program.
Go combines the advantages of such languages as C (static typing and run-time), Python, and JavaScript . You are probably well aware about the characteristics of Java, Python, C#, etc. Today we will learn about a little bit less popular and more modern language – Go.
